Python- creating a node from obj to out
logix1390
Hello,
I have run into a problem that needs a bit of python work. Basically what I am trying to do is create a mantra sop in the `out` context when I click a button in the `obj` context.
I found out how to create a node in the same context. For example:
 file_sop = hou.pwd().parent().createNode("file"); file_sop.parm("file").set(hou.pwd().Make_File_Button("sopoutput"))
This will create a file node on spot every time I click the "Make File Button". How can I tell it to place a mantra node in the `out` context where it belongs ?
I'm still a beginner in python, any help would be greatly appreciated .
I will attach my file for anyone that wants to take a look.
Thank you
python_make_node_button.hip
Try this code in your button.
hou.node("/out").createNode("ifd")
To discover information about any node just drop it into the python shell and print information from the various methods available.
print dir(n), using the variable displayed below, will provide you with the various methods available on any node.
Edited by Atom
