skin mirrored polygons
Spike
there is maybe a simple solution for that but after google and houdini forum i found no solution: I mirrored polygons , gave them points ids and connected them in the add sop by attribute (why does the add node create just lines and no polygons - in the polygon tab?! ) - and when i want to skin them - to create a connected mesh i get crossed polygons instead of "caps" on the side. Where is the problem - or the right approach? - Thank You for your help!
Edited by Spike
