madrenderman Posted September 21, 2018 Share Posted September 21, 2018 Hello, is it possible to move an object snapping to points/curves/grid but clicking directly on a specific point, without using the manipulator ? It's something I do all the time in Maya (on Maya documentation it's called “snap a move”) and saves a lot of time, maybe in Houdini it's possible but I don't know how. I attached a clip to better show what I mean. Thank you Ray 2018-09-21 12-09-15.mp4 Quote Link to comment Share on other sites More sharing options...
McNistor Posted September 21, 2018 Share Posted September 21, 2018 As far as I'm aware it's not possible in H. It's an old subject brought up by quite a few AFAIK. Multiple RFEs have also been filed most likely (I know I did) and should you add yours to the pile, it's only going to bump it up on SESI's list. Quote Link to comment Share on other sites More sharing options...
madrenderman Posted September 21, 2018 Author Share Posted September 21, 2018 Thank you, a user on Facebook found this "start orientation picking" option which is similar, do you know what is it ? https://www.facebook.com/alzosmol/videos/2183601271915408/ It moves the object but it rotates it too, it seems to be pretty similar though ... I'll fill an RFE Ray Quote Link to comment Share on other sites More sharing options...
McNistor Posted September 21, 2018 Share Posted September 21, 2018 Your link is either broken or it's not working for me because I'm not a FB user. If you can show the video through other means, I'll be able to give you my opinion on what's shown there. Quote Link to comment Share on other sites More sharing options...
WildayHeart Posted September 21, 2018 Share Posted September 21, 2018 Yes, please do the RFE - i have been asking for that for a while now. Same with other usual modeling operations that are very common in other programs. RFE them all! Quote Link to comment Share on other sites More sharing options...
madrenderman Posted September 21, 2018 Author Share Posted September 21, 2018 (edited) Look at this https://streamable.com/9vhs9 and https://drive.google.com/file/d/1_aLYxfOrh8QGNJSwb7sWhwAm4qj2Bnhu/view When you want to snap you need to press ; but on my keyboard (Italy) it doesn't work. If you CTRL+; it just moves, doesn't rotate Edited September 21, 2018 by madrenderman Quote Link to comment Share on other sites More sharing options...
McNistor Posted September 21, 2018 Share Posted September 21, 2018 (edited) OK, you can do "snap object to point" in Houdini, but that's enabled by what I previously thought and still hope is a bug, regarding aligning one's gizmo on a component (usually edge). I've described this weird behavior in another thread on SideFx forums and I'm still confused by what is this feature supposed to achieve: is it a snapping feature? If that is so, where are its options in the snapping prefs? I initially thought that it is a feature similar to XSI's one that allows you to align the gizmo after a picked component, for various transformation tricks. It being under "RMB > Align handle >" doesn't seem to support the "object snapping feature" hypothesis. So what is it? Talking about those preferences and their addressed concepts that are all over the place in Houdini. If it's not a snapping option, then it's a bugged/poorly conceived handle orientation feature that requires the user to perform two hotkeys in a row - detach handle (') and then start orientation picking (;) (do I really have to explain why that is an extremely poor design choice?) - that still hasn't been addressed in H 16.5. Edited September 21, 2018 by McNistor Quote Link to comment Share on other sites More sharing options...
McNistor Posted September 21, 2018 Share Posted September 21, 2018 Analyzing my response, seems like I've been caught up in my frustration with Houdini's viewport low-level matters ("frustration" being an overstatement, since I've given up the hope of doing direct modeling in H for now) and didn't address your issue: I'm not sure what problem you're experiencing. Regardless of what hotkey I use, (;) or (ctrl+;), I get the same result. Is this your main issue? Quote Link to comment Share on other sites More sharing options...
madrenderman Posted September 21, 2018 Author Share Posted September 21, 2018 It's not perfect but for me it's better than nothing ! I don't know why probably it's the iitalian keyboard, but to activate the function my shortcut is shift+; Quote Link to comment Share on other sites More sharing options...
