python-creating and selecting nodes
logix1390
Hello,
I have some python code that creates two different nodes in the `out` context.
My question is. how can I create multiple nodes in one line instead of two. So far I have this:
mantra=hou.node("/out").createNode("ifd");
hou.node("/out").createNode("geometry")
Is there a way I can shorten this line of code so that I can store both nodes that are being created in one variable?
My goal is to basically connect them as they are created.
Any help would be greatly appreciated.
thank you.
I don't think so, because there are additional tasks you may want to do as well. Like set flags, overwrite default parameter values, connect inputs and position them in the network etc..
def returnValidHoudiniNodeName(passedItem):
    # Thanks to Graham on OdForce for this function!
    # Replace any illegal characters for node names here.
    return re.sub("[^0-9a-zA-Z\.]+", "_", passedItem)
# Create the Material node.
mat_name = returnValidHoudiniNodeName("mat_%s" % local_name_only)
node_mat = node_geo.createNode("material", mat_name)
if node_mat != None:
	node_mat.parm("shop_materialpath1").set("/shop/%s" % shader_name)
	node_mat.setInput(0,node_uv)
	node_mat.moveToGoodPosition()
	node_mat.setDisplayFlag(1)
	node_mat.setRenderFlag(1)
Edited by Atom
Hi Atom,
Thank you for the response. I am not sure what is going on in the first half of the code.
What exactly is going on here? Thank you again.
