Transfering colors in attribute wrangler
netherknight
So I'm working with this attribute wrangler that makes a twisting braid around any curves I slot into it. However I am running into an issue where the original curves have a color but I can't seem to have the new twist inherit the color from the curve. Of course I can add a color node afterwards but that will only give it one color. Whereas my curves have multiple colors (each primitive has a different color).
float rad = ch('radius');
float pi = 3.1415926;
float t = 2.0 * pi  * ch('winding');
int copies = chi('strands');
int prim_pts[] = primpoints(0, @primnum);
for(int i = 0; i < copies; i++){
    int add_prim = addprim(0, "polyline");
    setprimintrinsic(0,"closed",add_prim,"toggle");
    setprimgroup(0,"twisted"+itoa(i+1),add_prim,1);
    setprimattrib(0,"Cd",add_prim,1);
    foreach(int pt; prim_pts){
        vector pt_p = point(0, "P", pt);
        vector pt_n = point(0, "Nloc", pt);
        vector pt_b = point(0, "Bloc", pt);
        vector uv = point(0,"uv",pt);
        float s =uv.x;
        float phase = 2*pi / copies * i;
        vector pt_pos = pt_p + pt_n * sin(s*t+phase)*rad + pt_b * cos(s*t+phase)*rad;
        int add_pt = addpoint(0, pt_pos);
        addvertex(0, add_prim, add_pt);
removeprim(0,@primnum,1);
Twist.hip
Edited by netherknight
