Christoph_H Posted September 28, 2018 Share Posted September 28, 2018 (edited) Hi, I have the problem that I can't get the double edge of a free line removed. I have already tested all the tools like: Fuse, Doctor, Clean. Fuse melts the dots together, but not the rest. Before fuse: Points: 36 Prims: 2 Verts: 36 Polys: 2 After fuse: Points: 18 Prims: 2 Verts: 36 Polys: 2 It still remains a problem and here are still double Edges. For example for the sweep node. I get double sweeps. Of course I can remove the double line manually, but it has to be procedural. Is it possible to equate the Verts with dots in a wrangler? thanks. Edited September 28, 2018 by Christoph_H Quote Link to comment Share on other sites More sharing options...
anim Posted September 28, 2018 Share Posted September 28, 2018 is it about curves? if so appending PolyPath SOP after Fuse can help for completely overlapping primitives both PolyDoctor and Clean SOP (since it uses PolyDoctor inside) after Fuse should work to fix overlaps for more complex geo or in general rather clean up your profile geo before sweep to avoid double sweeps Quote Link to comment Share on other sites More sharing options...
Christoph_H Posted October 2, 2018 Author Share Posted October 2, 2018 Great! Thanks for your help. Quote Link to comment Share on other sites More sharing options...
