Math noob - rotation formulas
art3mis
Hi
Trying to implement several of these rotation formulas with simple geometry
https://sites.google.com/site/fujitarium/technical-note/basic-math/rotation
for instance the first example
Quote
  • add rotation X (x, y*cos(rx) + z*sin(rx), y*-sin(rx) + z*cos(rx))
(x, y*cos(rx) + z*sin(Rx), y*-sin(rx) + z*cos(rx))
x = x
y = y*cos(rx) + z*sin(Rx)
z = y*-sin(rx) + z*cos(rx)
How would you implement this as Vex within a Point Wrangle?
Edited by art3mis
While rotating an object, we are essentially changing the position of the points of the Geo.
So, the above mentioned formula changes the point position along y and z axis but not x axis. To implement it in a point wrangle, just drop in a test object on to the grid followed by a point wrangle and enter the following code in the wrangle :
float angleX = ch("xRad");
float posY = @P.y*cos(angleX) + @P.z*sin(angleX);
float posZ = @P.y*(-sin(angleX)) + @P.z*cos(angleX);
@P = set(@P.x, posY, posZ);
Change the "xRad" parameter, the object "appears" to be rotating along the X-Axis, but in reality, it is just changing the point positions along Y and Z axis.
Hope it helps!
S
