Creating ALIAS for launching houdini
art3mis
Hi
Can anyone tell me if the following syntax is correct (on Ubuntu)? I'm prepending my PATH variable then launching houdini
> alias houdini_run='pathold=$PATH; PATH=/home/jim/yt-conda/bin:/home/jim/yt-conda/sbin; /opt/hfs16.5.595/bin/hindie-bin; PATH=$pathold'
The problem is when I run it, houdini DOES launch but I'm seeing a lot of missing package errors even though they definitely ARE installed in the bin directory defined in the above PATH.
ie
> sh: 1: grep: not found
> sh: 1: awk: not found
> sh: 1: ls: not found
