How to constrain the hand of simplefemale
AntoineSfx
You might try using actual driving footage as a reference. Or some classic movie with a driving scene you like (shot through the front window). Set your 3D camera to match the footage basic angle. Then manually set keys on the hand to match the footage as you chop through a few seconds.
Edited by Atom
Expand
The steering wheel is a part of a larger object, and it's moving as the vehicle follows a path.
I had some luck with the Points constraint, which also allows to use a direction attribute to set an orientation. I think it should be good enough to have the palm of the hand face the steering wheel.
It looks like the IK chain stops at the wrist, so I'll do the rest by hand. I would have been so nice to have IK for the fingertips and the palm..
