How can i call custom used defined function from another Wrangle node?
Hello!
I defined a custom vex function in Attribute Wrangle node, and i can call it only from this node, when i call it from different Attribute Wrangle node i get Undefined Function error.
Is there a way to declare a function in one node and to call it from the other node? The only way i found is to use external files with the #include filename.
You probably want to make a library to use functions in multiple wrangles. You can save files with a .vfl and add them to your environment with a HOUDINI_VEX_PATH variable. After that you can use a #include inside a wrangle to get your functions
