Dynamically Edit Parameter interface
kashmere
Hey guys, I am building a tool that needs to work on variations present in an asset package. And there are several different packages with different number of variations in them.
this is what I need to do -
on the surface level of my subnet, I need tick boxes[toggle] to turn a certain variation in the package on/off.
this is what I have -
I have wrangle inside the subnet that extracts the names of all the variations. Is it possible to populate the surface level of the subnet with these strings as labels for the toggle ?
I am planning to implement the toggle in a subsequent wangle, depending on which toggles are on,  I can delete the variation from the current stream.
But the catch is the number variations is not same for all incoming packages. How can I populate the parameter interface of the subnet to pick up the variations from the incoming stream?
