Axis channel with maketransform ?
CinnamonMetal
Append z to your channel reference (you can see this when hovering over the parameters text with your mouse):
f@whatever = ch("../testgeometry_pighead1/tz");
And better separate a function call like maketransform() from your remaining channel references and calculations.
Try to structure your code into sections like // INPUT, // PROCESSING, // OUTPUT instead of cramming everything into a one-liner
// INPUT
int trs  = chi('transformation_order');
int xyz  = chi('rotation_order');
vector t = vector(0.0); // setting up the vector for completeness sake, it will be overridden later
vector r = chv('rotation');
vector s = chv('scale');
vector p = chv('pivot');
float trans = ch('../test_geo/tz'); // grabbing a single translation value from another node
// PROCESSING
trans *= 2.0; // changing the value
t = set(trans, 0.0, 0.0); // combining the translation vector
matrix m = maketransform(trs, xyz, t, r, s, p); // setting up the transformation matrix, dont put any distracting stuff in here
// OUTPUT
@P *= m; // carry out
To ensure this example works, set the 'scale' parameter to 1, 1, 1 after clicking on the 'create parameters' button.
