bonassus Posted October 27, 2018 Share Posted October 27, 2018 I've discovered that I can create a subnet with multiple outputs by using multiple output nodes inside the subnet. This is useful how ever i can seem to add labels to the outputs. The default outputs are Output 1 (output1), 2 , 3 ect. the subnet comes with 4 inputs by default with string parameters for the labels. I don't see how these string parameters are hooked up to the inputs or how to add labels for my outputs. does anyone know how to do this? thanks Quote Link to comment Share on other sites More sharing options...
3dome Posted October 27, 2018 Share Posted October 27, 2018 the only way I know of is to turn the subnet into an HDA. Then in the options you can set input and output names 1 Quote Link to comment Share on other sites More sharing options...
