blast by particle ID
in the 'group' parameter of the blast SOP it would be @id=1 (or @id==1, both work). Don't specify the attrib type (i@, f@),.. Also important to set the group type so it knows where to look for that attrib!
In the delete SOP I don't know because I rarely use it..
EDIT: in the delete sop same thing, set to points, delete by expression then use a proper expression (coding) syntax with the == operator. Again, don't specify the type
Edited by 3dome
checked out delete sop
right, I forgot to mention: NO SPACES
well, a while ago you had to use that $ sign for all that which was annoying because you had to create a variable mapping for all the attribs you created. (i think you still can do that)
but as Houdini progressed, they opted to push everyone in the direction of VEX and allowed the @ outside of VEX for stuff like that
Edited by 3dome
