Valent Posted November 12, 2018 Share Posted November 12, 2018 I got really confused with multiple transform sops. I hate to ask such simplistic question, but the fact that I can't make it work means that I don't understand some fundamental concepts of Houdini. If I use them one after another, I thought that the second one would inherit transforms of the first one. in the example(Houdini 17 non-commercial) the first transform is animated and the second one is static(non-animated) but it is parented to the first one, so I expect it to follow the fist one, I mean the center of the second one should always be at the center of the first one, but it is true only if scale of the second one is set to 1. translate_scale_origin_q.hipnc Quote Link to comment Share on other sites More sharing options...
Valent Posted November 12, 2018 Author Share Posted November 12, 2018 ok, I guess I have found an answer, well sort of.. I have to make a reference of transform values of the previous transform nodes and put them as pivot transforms of the follow-up transform node. And, if the chain of these transforms is long, then the reference could look like: ch("../transform1/tx")+ch("../transform2/tx")+ch("../transform3/tx") ... +ch("../transform100/tx") is there a simpler way to do it? translate_scale_origin_a.hipnc Quote Link to comment Share on other sites More sharing options...
3dome Posted November 12, 2018 Share Posted November 12, 2018 well it's just like in maya with the transform groups or w/e that is called. (have a cube, ctrl+G to group and tranform that group, ctrl+G again and so on) you will see the pivot is also not in the center of the object anymore. And it's good that way. If you need the pivot in the center again after a transform, either use your expression or since you asked for a simpler way, put $CEX, $CEY, $CEZ in the corresponding fields instead of your expression 1 Quote Link to comment Share on other sites More sharing options...
Valent Posted November 12, 2018 Author Share Posted November 12, 2018 Thanks, it works! Also, could you please explain why (and how) the scale (of the last transform node) could affect position of that node (object)? I'd say, because in Houdini one transform-node inheriting transformations from an up-stream node, I expected it to be more like "parenting" objects in maya. Quote Link to comment Share on other sites More sharing options...
3dome Posted November 12, 2018 Share Posted November 12, 2018 (edited) If the pivot you scale from is not in the center of the object ($CEX,$CEY,$CEZ) then of course scaling affects the "position" (I guess by position you mean center as scaling always affects the position of points, no matter where the pivot is). They don't inherit anything. They all work in their own local space and have no idea what happened before. If you put the $variables in there, all you do is to change the origin of their local space. Parenting in Houdini is done on Scene level, not Object level, but generally behaves just the same Edited November 12, 2018 by 3dome 1 Quote Link to comment Share on other sites More sharing options...
