Arnold for Houdini 17. Anyone got it to work?
I downloaded HtoA 3.2.0 from
Installed also license server from here:
houdini env file was automatically edited by plugin installation. But i cant get it to work.
In houdini there is no arnold shelf and cant add it as there is no such shelf.
my Houdini env file looks like this:
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
#    VAR = VALUE
# Values may be quoted
#    VAR = "VALUE"
# Values may be empty
#    VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
# htoa config start
PATH = "$PATH;C:/Users/ISUther/Documents/Arnold_renderer/htoa-3.2.0_r9e1313b_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/Users/ISUther/Documents/Arnold_renderer/htoa-3.2.0_r9e1313b_houdini-${HOUDINI_VERSION};&"
# htoa config end
HOUDINI_DSO_ERROR = 2
PATH = "C:/ProgramData/Redshift/bin;$PATH"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/17.0.352;&"
HOUDINI_NVIDIA_OPTIX_DSO_PATH = C:/Users/ISUther/Documents/houdini17.0\optix
Note! i do have redshift also installed, but i wanted to try Arnold for skin shaders as i am trying to pick a rendering engine for houdini.
Arnold itself (that installation) is installed to directory as:
C:\Users\ISUther\Documents\Arnold_renderer
I have installed Houdini 17.0.352
And arnold for houdini is version 3.2.0-165753147
here is how mine got setup
if it may help in some way
I did change the path the second time again, the first time did not show up for me either.
To
new installed to:
C:/HTOA17
# the environment.
#    VAR = VALUE
#    VAR = "VALUE"
#    VAR =
# Example:
# htoa config start
PATH = "$PATH;C:/HTOA17/htoa-3.2.0_r9e1313b_houdini-${HOUDINI_VERSION}/scripts/bin"
HOUDINI_PATH = "C:/HTOA17/htoa-3.2.0_r9e1313b_houdini-${HOUDINI_VERSION};&"
# htoa config end
Edited by mangi
I got it working but now have new issue.
Arnold trial renders object as it has lights on it even tho i have 0 lights added
I am first time using Arnold. Should it work this way?
And when i add a light and try to change the intensity nothing happens renders out same way
Edited by ISUther
With no Arnold Lights
This will come up in the render with no Arnold Lights and No Arnold Shader.
It will pick up mantra default light:
Are you seeing something like this ????
Mangic
Edited by mangi
You have to build a Arnold Shader.
Here is how.
Mangic
HTOA17 Arnold shader.mp4
HTOA:
https://docs.arnoldrenderer.com/display/A5AFHUG/Shaders
Also just incase you need to assign the Arnold Render aswell. OK
Here is a real Kool intro to Arnold with Houdini,
1:30 starts to build an Arnold Shader
Mangic
Edited by mangi
7 minutes ago, mangi said:
Thnx again. :)
Also trying to figure out why i get this error.. happens when i start tweaking parameters in Arnold "ropnet1"
Atm trying to figure out other issue:
00:00:06 2065MB WARNING | [htoa.node.node] [soho] Parameter not found: radius (ar_radius) 00:00:21 2150MB WARNING | [htoa.node.node] [soho] Parameter not found: radius (ar_radius) 00:00:22 2186MB WARNING | [htoa.node.node] [soho] Parameter not found: radius (ar_radius)
Looks like these AISHADERS are not programed for these vesion:
I just set that folder up and I get the same result as you.
So I don´t know if there is any new AISHADERS for these versions.
I am not sure OKAY.
I Found these ARNOLD Tutorials this morning.
https://www.youtube.com/channel/UC1KDwEVBlxr4ew7xqLOhu9g
Edited by mangi
15 hours ago, mangi said:
I am not sure OKAY.
Hey!
Thank you so much for trying to help. This means a lot to me.
As when i study myself and no mentor i some times study something and then discover that it is no longer done this way or it does not work any more with this or that is some times frusturating.
regards AL shaders i got this info>
https://answers.arnoldrenderer.com/questions/10628/arnold-trial-renders-object-as-it-has-lights-on-it.html?childToView=10693#answer-10693
alshaders is not longer being developed.
Also have problem. I do not have AIImage node and i think i am missing some other nodes also.
Edited by ISUther
  • Downvote 1
Hi Tanel.
Just for the test purpose I did the following:
This way Arnold will find the AIshader.
The thing is they don´t work on this last version of arnold and Houdini 17.
Not really to sure what was the last version ?
I am looking around on internet to see okay ...
But it will be difficult to get those shader if they don´t develope them any more.
Ther mat be some older version...
Edited by mangi
