JFWfilms Posted November 23, 2018 Share Posted November 23, 2018 Hi I'm following a tutorial and the Texture VOP Node has S and T inputs but mine doesn't. I'm using Houdini apprentice 17.0.325. I can't find the Inputs. I've looked in the help, and the node in there is different to mine (the same as in the tutorial). Basically what I have done, is feed points in to a uv texture node . Then that into an Attribute VOP, and inside the Attribute VOP, I've imported the points and converted them to float with a vectofloat node, then I would feed that into the S and T inputs? Thanks Josh Quote Link to comment Share on other sites More sharing options...
A-OC Posted November 23, 2018 Share Posted November 23, 2018 You can plug your S and T values into a float to vector, and then its output to the uv input on the texture vop Quote Link to comment Share on other sites More sharing options...
JFWfilms Posted November 23, 2018 Author Share Posted November 23, 2018 I'm confused the S and T inputs aren't on my Texture VOP. But I've stolen the Node from the tutorial project file and that has the S and T inputs, However the texture still doesn't show up. I've attached an image of how I've set it up, and the result. The points just go a light grey. Quote Link to comment Share on other sites More sharing options...
A-OC Posted November 23, 2018 Share Posted November 23, 2018 You need to post the scene file Quote Link to comment Share on other sites More sharing options...
mangi Posted November 23, 2018 Share Posted November 23, 2018 (edited) Hi , ???? http://www.sidefx.com/docs/houdini/nodes/vop/texture.html Maybe you need UV CORDs "http://www.sidefx.com/docs/houdini/nodes/vop/uvproject.html" "A-OC" just saw your post as I was adding a remark "Thinking alike" without a scene ..... Edited November 23, 2018 by mangi Quote Link to comment Share on other sites More sharing options...
JFWfilms Posted November 23, 2018 Author Share Posted November 23, 2018 Here's the scene File: ImageBased_Destruction_Test .hipnc Thanks Quote Link to comment Share on other sites More sharing options...
A-OC Posted November 24, 2018 Share Posted November 24, 2018 The problem is that you don't have vertices, so switch to point class in the uv texture SOP and your image should show up. Quote Link to comment Share on other sites More sharing options...
JFWfilms Posted November 24, 2018 Author Share Posted November 24, 2018 Ah yes brilliant thank you so much! Quote Link to comment Share on other sites More sharing options...
