HQUEUE Job Fails
Hello,
I'm stucked, I think I managed to install and configure Hqueue correctly.
This is what I do:
-Plug a HQrender node after mantra's
-Submit Job then Open HQueue
The Job is submitted but after 3sec. it fails and the worst part is I don't know how to check what's wrong… If i click on the Job id number, it opens the Job details window but I can't see any “output log” to download.
If I go in the Clients window, i can see that my Client machine is recognized with Avaibality set to Any @anytime.
The server machine is a macpro 3,7 GHz Quad-Core Xeon E5, the client is an Imac 3,2 GHz Intel Core i3
Any idea where to start to resolve the problem?
Thanks!!
I kind of solved a part of the problem but now I have this:
The Houdini 17.0.352 environment has been initialized. Loading .hip file
/Users/JULES/Dropbox/PROJECTS/HOUDINI/Hqueue_test.hipnc. ERROR: Cannot find file
It seems it's still looking for the HIP file on the client machine. Weird because both machines (client and server) have the file located at the same place via dropbox..
Edited by JulesGuerin
Ok, I think I will try to explain how things are setu pand see I can get some precious help :)
My server-workstation have the shared folder located at /Users/JULES/Documents/PROJECTS
This PROJECT folder is mounted on my client machine at the root of the shared volume.
This is specified in the hqserver.ini file like this:
hqserver.sharedNetwork.path.macosx = /Users/JULES/Documents/PROJECTS
hqserver.sharedNetwork.mount.macosx = /Volumes/PROJECTS
On the client machine, in the HQClient folder, i modified the hqnode.ini file to point to this
[main]
server = Mac-Pro-de-Jules.local port = 5000 sharedNetwork.mount = /Volumes/PROJECTS
[job_environment]
Though the client still doesn't find the HIP file.
2 hours ago, ikoon said:
I had difficulties when I had PC addresses defined as names. Now I have everything set as IP numbers and it works fine.
Thanks Jiri! I changed the addresses to be as IP numbers but haven't had success :(
Strange thing is that it's trying to point to a folder that is not the correct folder anymore...
Loading .hip file /Users/JULES/Dropbox/PROJECTS/HOUDINI/Hqueue_test.hipnc.
ERROR: Cannot find file /Users/JULES/Dropbox/PROJECTS/HOUDINI/Hqueue_test.hipnc
But in the hqserver.ini I've changed this shared folder to be
I'm confused! Is there any other place than the hqserver.ini file where I should check if it's pointing to the correct shared folder?
