pyro cache issue
MitchFields
Hello,
I'm probably doing something really dumb, but I'm unable to get my smoke simulation to show in the viewport without being inside of the dopnet. (I'm still pretty new to these complicated simulations.) I've tried visualizing and also caching many different ways, also tried converting my caches as well. My simulation also doesn't show up when turning off/on the visibility of my geometry node. I've cached under the Pyro preset from dop I/O, imported right back in, nothing. Show all objects is on...  There's no lighting enabled in the viewport... I've updated the scene view pane... Saved and opened up the file again... I really just don't know. I have density, I have temperature, I should be able to see it.
Using 16.5 - I appreciate any kind of help, thank you.
I never used the "DOP Node" field, but from the help:
Quote
All the objects created by this node will be imported.
So my guess is, if you point to your smokeobject in DOPs, it'll work aswell. Sounds usefull if you want to import multiple objects, but I've always used something like "smokeobject*" as the default object.
Maybe someone else can elaborate on usecases for the DOP Node?
