Check if directory exists with hscript
Mzigaib
Is there a way to check if a directory exists with hscript? I try this:
set txt=''
foreach dir(`run('uls -p /mnt/non_existente/directory')`)
    if ($dir != "")
        set txt = 'nothing'
    else
        set txt = 'all'
end
message $txt
But if the directory doesn't exist it return me nothing, any tips?
Thanks.
I found a way:
# Check if directory exists
set check=''
foreach dir(`system(" if [ -d 'your_directory_path_or_not' ];then echo 'yes';else echo 'not';fi")`)
    if (`strmatch($dir,"not")`==1)
        set check = 'Not Found'
    else
        set check = 'Found'
    endif
end
message $check
But if anyone have a better and more elegant way let me know.
Thanks.
Edited by Mzigaib
