DaJuice Posted February 13, 2021 Author Share Posted February 13, 2021 Hi @davidyannick The lines you'll want to tweak are: PRESSED_HIGH PRESSED_LOW SELECTION_BASE MenuSelectedBG 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted February 13, 2021 Share Posted February 13, 2021 On 2/13/2021 at 5:04 AM, DaJuice said: Hi @davidyannick The lines you'll want to tweak are: PRESSED_HIGH PRESSED_LOW SELECTION_BASE MenuSelectedBG Expand Thank you for your help Quote Link to comment Share on other sites More sharing options...
wudangzhenren Posted November 26, 2021 Share Posted November 26, 2021 do you know how to change this background color?Thank you very much! Quote Link to comment Share on other sites More sharing options...
DaJuice Posted November 26, 2021 Author Share Posted November 26, 2021 Hi wudangzhenren, there are new properties for controlling those colors in the Houdini 19 color schemes. If you search the default .hcs files in the houdini install directory you will find new "Group" entries such as this: GroupBorder: DRKBORDER GroupHeader0: GREY(0.20) GroupHeaderTop0: GREY(0.20) GroupHeaderHi0: GREY(0.32) GroupHeaderHiTop0: GREY(0.32) GroupHeaderOpen0: GREY(0.31) GroupHeaderOpenTop0: GREY(0.31) GroupHeaderDisabled0: GREY(0.20) GroupHeaderDisabledTop0:GREY(0.20) GroupBody0: GREY(0.24) I am currently in the process of updating my color schemes for H19. For now, here is the updated Smoke theme. ST-NodeGraphSmoke.inc ST-Smoke.hcs 2 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted December 15, 2021 Share Posted December 15, 2021 I've found this theme on Sidefx forum, but it is not enough dark for me , can someone give me where to change this grey to a darker grey and the line color please Thanks for your help Quote Link to comment Share on other sites More sharing options...
DaJuice Posted December 21, 2021 Author Share Posted December 21, 2021 Hi @davidyannick Pane background color is DRKBASE in the .hcs file Path bar is probably PathGadgetGradHi and PathGadgetGradLow The timeline was one of the DopeSheet entries I believe Network editor background color is GraphBackground, which is found in the .inc files. The wire color should be GraphWire, again in the .inc file. Confusingly, the VOP graph wires are set in the .hcs files. Hope that helps 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted December 21, 2021 Share Posted December 21, 2021 On 12/21/2021 at 3:22 PM, DaJuice said: Hi @davidyannick Pane background color is DRKBASE in the .hcs file Path bar is probably PathGadgetGradHi and PathGadgetGradLow The timeline was one of the DopeSheet entries I believe Network editor background color is GraphBackground, which is found in the .inc files. The wire color should be GraphWire, again in the .inc file. Confusingly, the VOP graph wires are set in the .hcs files. Hope that helps Expand Thank you for your help Quote Link to comment Share on other sites More sharing options...
davidyannick Posted May 28, 2022 Share Posted May 28, 2022 I'm trying to tweak again one of the themes, I'd like to know what are the parameters to modify to have flat looking like on "slate " theme, maybe someone can help me Thanks for your help From this to this Quote Link to comment Share on other sites More sharing options...
unhrt Posted January 22, 2023 Share Posted January 22, 2023 On 11/26/2021 at 11:11 AM, DaJuice said: Привет wudangzhenren, есть новые свойства для управления этими цветами в цветовых схемах Houdini 19. Если вы ищете файлы .hcs по умолчанию в каталоге установки houdini, вы найдете новые записи «Группа», такие как это: В настоящее время я обновляю свои цветовые схемы для H19. А пока вот обновленная тема Smoke. ST-NodeGraphSmoke.inc ST-Smoke.hcs Expand Thanks for your work. Could you tell me how I can make multi-colored tabs like you have in the very first post? Quote Link to comment Share on other sites More sharing options...
DaJuice Posted February 2, 2023 Author Share Posted February 2, 2023 On 1/22/2023 at 12:59 PM, unhrt said: Thanks for your work. Could you tell me how I can make multi-colored tabs like you have in the very first post? Expand Hi Alex, you probably already figured it out, but this option can be found under Preferences > General User Interface > Color Pane Headers with Network Contexts Quote Link to comment Share on other sites More sharing options...
