OpenGL parallel texture alpha?
dgani
Hi all,
I need to use OpenGL cards for a project, and I'm noticing an issue with transparency. In the pictures below I have a transparent tif. From head on, the alpha works perfectly and I can see everything behind the texture. The more I look at it from the side, the transparency goes away until it is basically opaque. I noticed in the OpenGL docs http://www.sidefx.com/docs/houdini/props/material.html#ogl that there are separate tags for alpha and alpha parallel. I can't find any way to apply the image alpha to the parallel alpha though. It works fine if I turn off use lighting, but I actually need to light my cards for this one.
Any help is much appreciated! Thanks for taking the time to read.
Dylan
