Marcocheng Posted December 16, 2018 Share Posted December 16, 2018 (edited) Hello folks! I'm trying to make a wood fracture with a bullet sim. I fracture the object with boolean then set-up a basic bullet solver. Everything goes perfectly until I add glue constraints. I use connect adjacent pieces as usual, then when I load it with glue constraint relationship and play the simulation, Houdini crashes. Without the constraints, Houdini doesn't crash... My Houdini is 16.0.736 (stable version as Houdini official), Here's the source file... Thanks! Marco Wood_Fracture.Bug.hipnc Edited December 16, 2018 by Marcocheng Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted December 16, 2018 Share Posted December 16, 2018 Houdini 17.0.382 work good with your scene, Houdini 16.0.884 crashes. Use unpack node instead of packedit 1 Quote Link to comment Share on other sites More sharing options...
Marcocheng Posted December 16, 2018 Author Share Posted December 16, 2018 1 hour ago, vicvvsh said: Houdini 17.0.382 work good with your scene, Houdini 16.0.884 crashes. Use unpack node instead of packedit Oh seems the pack edit cause the problem... thank you! You made my day Quote Link to comment Share on other sites More sharing options...
