Vellum cloth - removing stretch
art3mis
Thought this should be self evident and simple.
On the Vellum Cloth Constraints SOP simply crank up the Stiffness value under Stretch.
But no matter what values I use there is still huge amounts of stretch as visible in the larger polys near the top of my simulated cloth.
How to remove stretch entirely?
Edited by art3mis
  • 1 month later...
I've encountered a similar problem. The peak of the cloth gets completely blown out.
Is there any possibilty to get an even stretching?
Maybe a way would be to somehow change the exponen of the pulling force dependent on the rest/current length ratio?
Futile solution attempts:
- Changing Stretch Stiffness
- Increasing Subdivisions
In the attached video demonstrates the problem.
stretch.mp4
Edited by AlSk
while having enough substeps and constraint iterations is important for cloth to converge,
in your case you are forcing your cloth to stretch so it can't converge fully to constraint rest lengths, which may cause artifacts you are seeing as every constraint tries as hard as it can, but unlucky points around collisions will always lose as collisions will move them back
you'll need to decrease Stiffness a lot to like 1000 or 10000 to allow the cloth to stretch, then furthermore increase Smoothing steps to get more even stretching
also you can increase collision iterations to get better ratio of interleaved constraint/collision iterations
What I actually need is a The Frighteners like effect where a figure stretches and deforms the ground in a 'clothy' manner.
I noticed that the blow out is caused by a too little friction that can't counteract the pulling of the stretch. So the cloth gets stretch infinitely.
Increasing the friction on the other hand leads to conflicts with the constraints. The cloth on the borders of the collision object starts to jitter.
So in the end I got the best result so far with the following settings:
    - Constraint Iterations: 1
    - Static Threshold: 0
    - Dynamic Scale: 5
    - Enable Self: 0
    - Substeps 1 and the rest default
Seems kind of hacky, but more Substeps and Constraint Iterations made it in my case even worse.
Attached before and after.
now_v0011_o0001.mp4
before_v0010_o0001.mp4
Edited by AlSk
