H17 has different voronoi fracture node
juncho
Hello, I'm trying to use voronoifracture node and found that it's different from the previous version(H16.5).
So I imported to H17 from my old project made with H16.5 and now I have two different SOP named same. Is there any way to create the old voronifracture node in H17?
One on the left side is new voronoifracture node in H17, and the right one is imported from my project made with H16.5.
Thanks in advance!
There is indeed. If you go to Windows > Hscript Textport
type: opunhide
This will give you  list of all the older nodes that are being made redundant. Find the 'ophide Sop voronoifracture' and then type it into the Hscript textport, changing 'ophide' for 'opunhide'.
This should make a the old voronoifracture node accessible in the network view.
Let me know how you get on :)
  • 1 month later...
type: opunhide
Thank you! Wonder why I could not get the reply notification.
This worked for me :D
