kirkhuisc Posted December 31, 2018 Share Posted December 31, 2018 hi guys, I'm trying to make the Modeling the leaf venation, but i have no idea how to make it... who can help? Quote Link to comment Share on other sites More sharing options...
kiryha Posted December 31, 2018 Share Posted December 31, 2018 One of the possible options (if you are looking for a procedural solution) is a Space Colonization Algorithm. Here is an example file. In case of leaves, you would need to scatter points on a flat surface instead of the volume. 1 Quote Link to comment Share on other sites More sharing options...
zarralax Posted January 3, 2019 Share Posted January 3, 2019 On 12/31/2018 at 6:03 AM, kiryha said: One of the possible options (if you are looking for a procedural solution) is a Space Colonization Algorithm. Here is an example file. In case of leaves, you would need to scatter points on a flat surface instead of the volume. nice Algorithm!, i did a quick test: Quote Link to comment Share on other sites More sharing options...
