art3mis Posted January 2, 2019 Share Posted January 2, 2019 (edited) Hi Trying to blend 2 meshes of the same character imported in FBX format. One is in static T-Pose. The other is animated. I assume you need to use a Blend Shapes SOP but have had zero luck getting it to work. Any rigging experts possibly able to set up a bare bones(pun intended) .hip showing how to accomplish this? OP solved . In my case using a Sequence Blend was all I needed. Edited January 3, 2019 by art3mis Quote Link to comment Share on other sites More sharing options...
