vex function to read all the attributes of a point?
pelos
string pointattribs[] = detailintrinsic(0,"pointattributes");
this gives you a list of pointattribs that allready exist, the problem is to create the attributes on your new point. The problem is that you dont know the attribtype (float,string,vector). You can somehow use attribsize combined with pointattribtype to check what it is. It becomes alot of if statements if you want it to be rock solid. Personaly i have ignored some types to make it simpler.
void transferPoint(int input;int fromPoint ;int toPoint){
    string pointattribs[] = detailintrinsic(input,"pointattributes");
    foreach(string name;pointattribs){
        int found = 0;
        int size = attribsize(input,"point",name);
        int type = pointattribtype(input,name);
        if(type == 0){
            int attrib = pointattrib(input,name,fromPoint,found);
            setpointattrib(0,name,toPoint,attrib,"set");
        if(type == 1 && size == 1){
            float attrib = pointattrib(input,name,fromPoint,found);
        if(type == 2){
            string attrib = pointattrib(input,name,fromPoint,found);
        if(type == 1 && size >= 2){
            if(size == 4){
                vector4 attrib = pointattrib(input,name,fromPoint,found);
            else{
                vector attrib = pointattrib(input,name,fromPoint,found);
  • Thanks 1
mmm  sometimes i think the vex datatypes are very limited, i was expecting to get a list of classes such
pointclass1,
pointclass2,
that later on with .notation i could get properties like the size, type, name etc..
(something i like a to work with python more than vex)
thanks for sharing the snippet, i appreciate it =)
If you want to transfer just from 1 point you can provide that point as a reference for addpoint() function
To get interpolated attributes between 2 or more points you can also just use Attribute Interpolate SOP after your wrangle to do the job based on arrays of point numbers and weights that you provide
Edited by anim
