logix1390 Posted January 8, 2019 Share Posted January 8, 2019 I have a bit of an interesting problem which I thought was going to be easy I have one of Houdini's pictures loaded in : Mandril.pic I want to change only the red areas to whatever color I want. I know there is the hue shift and color correct nodes... but that will hue shift all the colors at the same time. How do I only Hue shift the red channel to change it to whatever color i want??? vector to float >float to vector doesn't seem to work for this situation ...probably because Cd.x is not a vector... This is driving me a little crazy... I will attach my scene file with my attempted methods. Thank you change_color_component.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted January 8, 2019 Share Posted January 8, 2019 just approach it like comp create mask from your channel and blend original and corrected color using that mask change_color_component_fix.hipnc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted January 8, 2019 Share Posted January 8, 2019 (edited) In a point wrangle create an amount parameter (line 1) and convert the color values to HSV (line 2). Choose a range within the hue spectrum that is supposed to change (line 3). Multiply it by the amount and add the result to the hue component of the HSV color (line 4). Convert the color vector back to RGB (line 5). float amount = chf('hue_shift'); vector col_hsv = rgbtohsv(v@Cd); float range = chramp('mask_by_hue', col_hsv.x); col_hsv.x += amount * range; v@Cd = hsvtorgb(col_hsv); change_color_component2.hipnc Edited January 8, 2019 by konstantin magnus Quote Link to comment Share on other sites More sharing options...
logix1390 Posted January 9, 2019 Author Share Posted January 9, 2019 thanks guys, this works great Quote Link to comment Share on other sites More sharing options...
