timj Posted January 15, 2019 Share Posted January 15, 2019 Does anyone know hot to build a morph vop like this? ITS ON 15:45 Just the transform from the one into the other shape Quote Link to comment Share on other sites More sharing options...
Sepu Posted January 15, 2019 Share Posted January 15, 2019 did you check the other thread that I respond? Quote Link to comment Share on other sites More sharing options...
timj Posted January 15, 2019 Author Share Posted January 15, 2019 yeahy sorry for not replying. Just wonder how you get the morp transform, alredy tried wih mops etc. Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted January 15, 2019 Share Posted January 15, 2019 Hi, here is an idea: As input you have a source + target curve and a polyline with many points. Identifying each point with the u parameter of both curve you can move this point in between. A good way to have control over this is using a ramp. Check the attached file and try to move (all) ramp values horizontal from left to right (or back). morph_curve.hipnc 1 Quote Link to comment Share on other sites More sharing options...
timj Posted January 16, 2019 Author Share Posted January 16, 2019 Thanks so much for the result! I will try it now in vex ! Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted January 16, 2019 Share Posted January 16, 2019 Sure man, according to the video it seems to be easier to add an offset parameter (instead of moving the ramp keys) to have control over morph process. Another idea can be adding another ramp to add a custom offset, if you have multiple curves in a for each. morph_curves.hipnc Quote Link to comment Share on other sites More sharing options...
timj Posted January 16, 2019 Author Share Posted January 16, 2019 Thanks, already did a for-each loop and it works perfecly! Thanks so much! 1 Quote Link to comment Share on other sites More sharing options...
wufan927 Posted September 27, 2021 Share Posted September 27, 2021 tried one without foreachknitting test.hipnc Quote Link to comment Share on other sites More sharing options...
