Mogul4200 Posted January 16, 2019 Share Posted January 16, 2019 I am on a project to make a wind tunnel. I have the pyro stream pretty good. What I am trying to add is some measurements from the simulation. Is there a way to measure the velocity at certain points in the simulation? Or something that I have no idea about is that if there is a good way to measure it, how do I display it? Thank you for some help Quote Link to comment Share on other sites More sharing options...
char Posted January 16, 2019 Share Posted January 16, 2019 I think the Volume Visualisation / Volume Trail might be something to look into, you can trail the velocity in your sim and based on color see where it peaks and where it's the lowest. Quote Link to comment Share on other sites More sharing options...
jamesr Posted January 16, 2019 Share Posted January 16, 2019 There's several ways to do that. Here's couple I threw together that I think you might have been talking about. Let me know if it helps! voltrailviz.hip 1 Quote Link to comment Share on other sites More sharing options...
Mogul4200 Posted January 17, 2019 Author Share Posted January 17, 2019 4 hours ago, jamesr said: There's several ways to do that. Here's couple I threw together that I think you might have been talking about. Let me know if it helps! Thanks for the response. I am in the process of checking it out. Having some problems with the file. What version did you make it in? Quote Link to comment Share on other sites More sharing options...
jamesr Posted January 17, 2019 Share Posted January 17, 2019 (edited) Latest production build — 17.0.459 Edited January 17, 2019 by jamesr Quote Link to comment Share on other sites More sharing options...
