Synergy Crashing
Jason
Hi there,
I'm not sure if this happens for anyone else or not, but it seems like "synergys" (Synergy Server) crashes when I use Houdini these days. (Linux RH9). I have used for quite some time but then I started noticing that synergy would just stop working during a Houdini session. I blamed my Windows (client) machine, naturally; but then I noticed that synergys on my Linux machine was just quitting.
Now I'm pretty convinced that it quits soon after I start using Houdini on my Linux box. Has anyone else noticed this?
Cheers,
Jason
PS. I also have strange MMB behaviour at home using my Logitec Lazer-mouse on Windows2000 where any MMB click takes about 4 secs to kick in and then often lock in this state for a while - and this is only when I use Houdini. This makes Houdini pretty unusable on my home machine. I was wondering if Houdini was doing something with the pointer which freak out the Logitec drivers and Synergy? I was hoping to hear of anyone else's troubles before bugging SESI about this.
PPS. I'm talking about the excellent open-source Synergy mouse/keyboard sharing utility: Synergy Site
I use Synergy every day between my linux box and a windows2k laptop.
Linux: CentOS release 4.1 (Final)
Synergys: 1.1.10 (server running under linux)
It's been remarkably stable for me actually. My synergy version is pretty out of date, probably been running this setup for a year or so w/out much problem. Maybe newer versions of synergy are buggy? I don't know what features you'd loose if you versioned back.
BTW, I'm also running H8.0.383
-Daniel
I've tried all versions of Synergy with no marked improvement, unfortunately. I'm on 8.0.589 and so it might seem like something in Houdini has changed a bit since 8.0.383. It's a little odd because Synergy doesn't crash immediately; it takes a while. I'm still trying to figure out why.
Ah well, I'll keep looking.
hi !
i also own laser logitech g5, and i am experiencing same problem only it just stays pressed down. In addition to that, sometimes when i press MMB, it wants to scroll down, what annoys me as well. I am running ubuntu 5.10, and i have intel mb.
kumpa
You could try and run the server on the windows side instead?
d
28062[/snapback]
The Windows side is my laptop and my linux is my Linux workstation. I can't imagine having to use a tiny keyboard and the two-button touchpad on my laptop to control my pointer on my dual monitor linux box ;)
I'd have to set an an additional mouse and keyboard to my laptop every day I bring it in and then what do I need Synergy for then? (besides the cut&pastel... which is cool...).
If Houdini is messing with Logitec drivers and crashing Synergy then perhaps there it's being a little brutal or unorthodox somewhere along the line?
28187[/snapback]
Ah right, of course. I was under the impression that you could have the laptop host but still drive from the Linux side. Not sure why I thought that was possible
d
  • 1 month later...
Just to follow up on this:
It seems like my synergy crashing has disappeared :-D -but I'm not terribly sure if it was that SESI addressed something in later builds of 8.1 or if it was related in my own switch from RH9 to FC4. I suspect the latter.
