jamalade Posted January 29, 2019 Share Posted January 29, 2019 Hello, I've setup a hqueue farm across several machines with a shared drive. Almost everything seems to be working now (had lot's of intermittent issues, with jobs not making it to hqueue and 0%progress fails[think perhaps there was a license conflict]) Anyway, current problem is that I am unable to overwrite dependencies in the shared folder when I resubmit the hqrender node. As far as I can tell there are no permission issues and the files are not being used. I can read/delete/edit these files no problem from any of my clients/server machines(also fine/not corrupt in local directory). Any thoughts? log below OUTPUT LOG ......................... 00:00:00 144MB | [rop_operators] Registering operators ... 00:00:00 145MB | [rop_operators] operator registration done. 00:00:00 170MB | [vop_shaders] Registering shaders ... 00:00:00 172MB | [vop_shaders] shader registration done. 00:00:00 172MB | [htoa_op] End registration. 00:00:00 172MB | 00:00:00 172MB | releasing resources 00:00:00 172MB | Arnold shutdown Loading .hip file \\192.168.0.123\Cache/projects/testSubmit-2_deletenoChace_2.hip. PROGRESS: 0%ERROR: The attempted operation failed. Error: Unable to save geometry for: /obj/sphere1/file1 SOP Error: Unable to read file "//192.168.0.123/Cache/projects/geo/spinning_1.23.bgeo.sc". GeometryIO[hjson]: Unable to open file '//192.168.0.123/Cache/projects/geo/spinning_1.23.bgeo.sc' Backend IO Thanks in advance Quote Link to comment Share on other sites More sharing options...
jamalade Posted February 6, 2019 Author Share Posted February 6, 2019 I know there are 101 factors at play with Hqueue and diagnosing problems from random scrawlings without system/scene info is generally not that feasible but I'm hoping this error message will jog someones memory. "mantra: Error writing data to image device" basically jobs on the hqueue farm seem to intermittently stall with this error "mantra: Error writing data to image device" If i reset the hqclientd.bat on client machines, then a few frames will get rendered but eventually one will stall followed by the rest with the same error. Everyone is admin, ports all open, no files to overwrite. A permission element i've overlooked somewhere(which would make sense given my first unresolved first post issue)? drive bandwith limit/?, (I'm not a tech guy, i prefer moving points around with vex ) (On Windows 7) I'll keep digging.. Quote Link to comment Share on other sites More sharing options...
