Matching Houdini camera with zbrush 30 perspective view
ISUther
Hello,
I have a model from zbrush.
Angle of view for model in zbrush was set to 30.
Model was saved and imported to Houdini.
Houdini camera was created.
I need to match houdini camera to zbrush camera
Need to change:
FOV (horisontal) (degrees) to 41.1
FOV (vertical) (degrees) to 28.1
FOV (diagonal) (degrees) to 48.5
But i cant as option is grayed out and can`t even find diagonal one.
Here you see model looks different in Houdini then it looks in Zbrush:
Here is where they speak about camera differences
https://sortadone.blogspot.com/p/zbrush-focal-angle-tutorial.html?fbclid=IwAR0iyAsEHxs9dkuTy7VAUIPI4AG5u_8qZic2xBojfruodUHAHMzfiq68fU8
I think same applies to houdini also.
Under this section i was calculating angle
http://www.tawbaware.com/maxlyons/calc.htm
Could not find any option for changing those settings in Houdini
I saw 2 options under redshift camera settings.
Horisontal FOV and Vertical FOV (But not diagonal)
All were grayed out.
When i changed Camera Projection to Fisheye Projection it enabled only 2 options.
But not all.
https://www.youtube.com/watch?v=Nfb5jWYtU-A&feature=youtu.be
Are you able to assist?
Edited by ISUther
  • 3 weeks later...
