How to move 2 objects same time in Object level. Without moving both in to same geo folder / node
ISUther
You could use copy values and past copy relative values.
Just right click on the transformation rotacion scale what you want ,hen past relative values will give you the code.
then move etc.. the parent and this will put the value for you .....
M
7 hours ago, mangi said:
M
Thnx! it works :)
