anicg Posted February 11, 2019 Share Posted February 11, 2019 Is it possible in Houdini to export the terrain mesh in tiles? Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted February 11, 2019 Share Posted February 11, 2019 Petz solved this issue a few weeks ago: Quote Link to comment Share on other sites More sharing options...
anicg Posted February 12, 2019 Author Share Posted February 12, 2019 Thank you Here is a screenprint of the file (attached), which one works? 1. is your original python 2. it mentions he wants to get rid of it 3. only has a "file" are 2 and 3 related? I unbypassed the nodes, nothing happened Any idea how to make it work? Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted February 12, 2019 Share Posted February 12, 2019 (edited) Hi Mani, they all work except no.1, hence the thread. Petz` scripts (variants 3 to 5) write bgeo-files to the location where your houdini file is located. You can tell by: filePath = hou.hscriptExpandString("$HIP") Variant 2 was mine, but I found it visually too wasteful for just saving. Variant 3 uses some Python code inside the file node to increment the file names. Just click on the label 'Geometry file' to see it. 2 and 3 are related but Petz` variant is more compact. Variant 4 packs the fragments which makes handling and in this case exporting much easier. getEmbeddedGeometry() inside hou.PackedGeometry class seems crucial here. Variant 5 utilizes a Python SOP with two loops: First assigns the segment number to each primitive and the second deletes all non-related primitives before writing out all left-overs. Just look in your folder: You should get a list of objects ranging from part_0.bgeo to part_24.bgeo. The nodes just dont overwrite each others files, I think. Edited February 12, 2019 by konstantin magnus Quote Link to comment Share on other sites More sharing options...
anicg Posted February 14, 2019 Author Share Posted February 14, 2019 Thanks, excuse my ignorance, what do I change to get obj files (not bgeo)? Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted February 14, 2019 Share Posted February 14, 2019 It should be sufficient to simply replace bgeo by obj in the code, I think. Quote Link to comment Share on other sites More sharing options...
