juncho Posted February 12, 2019 Share Posted February 12, 2019 Hi, I got my Cone Twist Constraint Relationship node but I can't see the guide. For example, in the tutorial video (H15.5 is used in the tutorial) However, in my H17.0.459. I've selected the node but I can't see the guide. Quote Link to comment Share on other sites More sharing options...
Andrea Posted February 12, 2019 Share Posted February 12, 2019 (edited) Are you sure you imported correctly the constraints? (right constraint name and correct path) Also, make sure that "Show guide geometry" in constraintnetwork1 node is on. Edited February 12, 2019 by Andrea Quote Link to comment Share on other sites More sharing options...
juncho Posted February 13, 2019 Author Share Posted February 13, 2019 (edited) 8 hours ago, Andrea said: Are you sure you imported correctly the constraints? (right constraint name and correct path) Also, make sure that "Show guide geometry" in constraintnetwork1 node is on. Thanks for the reply. Constraints seem to be imported correctly since it behaves the way it supposed to. Moreover, I can't find Show guide geometry checkbox here! Photo below is my guide option tab from conetwistconrel node. Edited February 13, 2019 by juncho Quote Link to comment Share on other sites More sharing options...
Andrea Posted February 13, 2019 Share Posted February 13, 2019 I mean in the node called "constraintnetwork1". There is a checkbox where you can turn on and off the visualization of all the constraints Quote Link to comment Share on other sites More sharing options...
juncho Posted February 13, 2019 Author Share Posted February 13, 2019 2 hours ago, Andrea said: I mean in the node called "constraintnetwork1". There is a checkbox where you can turn on and off the visualization of all the constraints Still not working. Show Guide Geometry in "constraintnetwork1" does not display cone twist constraint relationship guides. Shall I give it a try in lower version of Houdini? Quote Link to comment Share on other sites More sharing options...
Andrea Posted February 13, 2019 Share Posted February 13, 2019 You can try, but don't think the problem is the Houdini built. I have the same version and the constraints are displayed as usual. Try to upload there the hipfile, would be a lot faster to figure it out Quote Link to comment Share on other sites More sharing options...
juncho Posted February 13, 2019 Author Share Posted February 13, 2019 (edited) 10 minutes ago, Andrea said: You can try, but don't think the problem is the Houdini built. I have the same version and the constraints are displayed as usual. Try to upload there the hipfile, would be a lot faster to figure it out Thank you for helping me out! Here is my hip file : iii.hip and here is the geometry in alembic file format : appliedhoudini.rigidsIII.helicopter.abc obj-> frac-> load abc in the import_heli node. cache the geometry in heli_cache node if necessary. constraints that is causing the problem is in obj->sim->Twist Let me know if there is any problem ! Edited February 13, 2019 by juncho Quote Link to comment Share on other sites More sharing options...
Andrea Posted February 13, 2019 Share Posted February 13, 2019 That's super strange. I don't have any issues there, I can see the cone constraint as usual placed at the origin. Can you try with this hip? iii_2.hip 1 Quote Link to comment Share on other sites More sharing options...
juncho Posted February 13, 2019 Author Share Posted February 13, 2019 31 minutes ago, Andrea said: That's super strange. I don't have any issues there, I can see the cone constraint as usual placed at the origin. Can you try with this hip? iii_2.hip This is weird. I've downloaded your file and now there's guides. What have I done wrong? Perhaps, I will continue working on the file you have uploaded. Thank you so much! Quote Link to comment Share on other sites More sharing options...
Andrea Posted February 13, 2019 Share Posted February 13, 2019 There was nothing wrong, that's what was strange. Maybe some nodes were somehow bugged, but I can't really tell Quote Link to comment Share on other sites More sharing options...
