Export Import alembic camera with Python
kiryha
Hi, guys
I need to exchange camera animation between scenes and I guess that Alembic is a good option for this. I can import the alembic camera:
OBJ = hou.node('/obj/')
CAM = OBJ.createNode('alembicarchive', 'CAM')
CAM.parm('fileName').set('C:/temp/cam.abc')
CAM.parm('buildHierarchy').pressButton()
Now I need to figure out how can I export the camera from my scene...
I can export camera with Alembic ROP but maybe there is a more elegant solution?
sceneRoot = hou.node('/obj/')
# Get camera object
camera = hou.node('obj/{}'.format(cameraName))
# Get Camera parent nodes
listCameraNodes = '{}'.format(camera.name())
for i in camera.inputAncestors():
    listCameraNodes += ' {}'.format(i.name())
# Create ROP network
ROP = sceneRoot.createNode('ropnet')
ABC = ROP.createNode('alembic')
ABC.parm('trange').set(1)
ABC.parm('filename').set('C:/temp/camera_001.abc')
ABC.parm('objects').set(listCameraNodes)
ABC.parm('execute').pressButton()
ROP.destroy()
cameraExportImportABC_001.hiplc
Edited by kiryha
To import a camera through alembic, a good solution is not to use the Build Hierarchy every time, but read the parameters directly from it using the module.
>>> import _alembic_hom_extensions as abc
http://www.sidefx.com/docs/houdini/hom/abc_extensions.html
From it you can pull out all the transformations and some data on the camera.
For export, it is better to have a HDA in which you could indicate the path to the camera where all its parameters would be read, after that the camera would be baked and then exported to Alembic.
