Mesh Border Mask
Solarize
Hello,
I'm quite new to Houdini and I have a pretty simple question which I haven't been able to figure out. Suppose an open convex plane, how can I make a mask from border to center going from black to white? Attached example images.
In my case, a height mask could do the trick too due to its convex shape, but ideally I prefer the border.
Thank you
assuming the shape is flat (it has to have boundaries) you can also do the following:
Use a divide sop to remove shared edges (toggle at the bottom), though it looks like on the left image this may already be the case.
Put an "primitive" or "ends" SOP and set the mode to "unroll" (easier to find in the ends sop), you should now have the boundary line.
then you can do the rest in an attribute VOP or wrangle, for example: (input the main geo in the first input, and the boundary in the second)
f@falloff = xyzdist(1, v@P);
v@Cd = f@falloff;
Edited by acey195
