Multiple vellum constraint property node's with different pressure
davidkvien
I am trying to inflate two spheres with different pressure in the same network. Problem is the spheres will both react to only one of the constraint property nodes. I am sure the solution has something to do with the bindings of the vellum source and the constrain property but I just cannot figure out how.
pressuretest.hip
