Textures not appearing [SOLVED]
ChazS
When pumped through a dop network, a basin, floor (terrain objs) and a cup (static obj) lose their textures and appear white in the scene view. Might be worth mentioning this has a flip pour out of the cup into the basin.
Btw, the entire scene won't render either. It gets hung up on "Generating Scene.....".
Anyone?
Edited by ChazS
Updated status
57 minutes ago, lukeiamyourfather said:
Do you have a specific question? Are you familiar with how materials can be assigned?
I believe I do... at least a little. :) In the render tab of the sop is a Material parameter, right? At least that's what worked before running it through the dop. If I shut off the dop and make the sops visible, they render fine, so I'm at a loss about why.
