want to store an attribute for some objects in 'foreach' loop
Valent
I think the problem here is that the values in the array gets overwritten by the insert function somehow. As the documentation says "the function will fill the gaps with uninitialized values (for example, or the empty string)".
Building it that way, at the moment I have no idea how to solve it. Even using the push function and adding elements to the array, doesn't work. Maybe you can store the height as prim/point attribute and add them later to the array?
  • Valent changed the title to want to store an attribute for some objects in 'foreach' loop
