PortalPyro98 Posted February 27, 2019 Share Posted February 27, 2019 (edited) Currently having problems with a vortex sim where pieces of the ground are ripped from the ground by setting the active attribute to 0 and using bounding box groups have pieces active attribute be turned to 1 and the vortex force drag them around a point. However I'm having a problem where some of the pieces suddenly have their active attribute turn back to 0 while in the air making them stop mid air. Just wondering if their is a way of having the active attribute always stay as 1 if it becomes part of the group. ActiveTest.hipncFetching info... AttackerHands2.abcFetching info... Edited February 27, 2019 by PortalPyro98 Quote Link to comment Share on other sites More sharing options...
MitchFields Posted February 27, 2019 Share Posted February 27, 2019 Looked at your file but don't have too much time, your bounding boxes are what sets your active attribute. As soon as your geometry leaves the bounding box, active will be 0. I would suggest using a solver to check if the attribute has ever been turned on.Grab the previous frame, if it was 1 then it is still 1, if it's 0 then it's still 0. That way whatever leaves your bounding box, will retain it's active attribute. Check Matt Estat's cgiwiki for information about the solver sop. http://www.tokeru.com/cgwiki/index.php?title=The_solver_sop 1 Quote Link to comment Share on other sites More sharing options...
PortalPyro98 Posted February 28, 2019 Author Share Posted February 28, 2019 On 2/27/2019 at 11:10 PM, MitchFields said: Looked at your file but don't have too much time, your bounding boxes are what sets your active attribute. As soon as your geometry leaves the bounding box, active will be 0. I would suggest using a solver to check if the attribute has ever been turned on.Grab the previous frame, if it was 1 then it is still 1, if it's 0 then it's still 0. That way whatever leaves your bounding box, will retain it's active attribute. Check Matt Estat's cgiwiki for information about the solver sop. http://www.tokeru.com/cgwiki/index.php?title=The_solver_sop Expand Thanks for the advice i got it to work using this If expression if anyone has similar issues. Quote Link to comment Share on other sites More sharing options...
MitchFields Posted March 13, 2019 Share Posted March 13, 2019 That's perfect! Great job man. Solver's are wonderful for this sort of stuff. Post a picture of your finished result whenever you get it done! Quote Link to comment Share on other sites More sharing options...
