Separate fluids with high viscosity
bobbybob
How is it possible to have two (High viscosity) fluids interact with each other, without mixing. Not mixing in the dop's or mixing in the "Particle fluid surface".
I am trying to arrive at a result that have the quality of this: See image
Edited by bobbybob
Just cache the final surface out one layer at a time and use the previous layer's surface as the collision object for the new layer. That is how a lot of those stacked candy or desert animations are approached.
Edited by Atom
  • Like 2
  • Thanks 1
