Setting or changing parameters with VEX
Krion
Hi.
A little basic question when reading the documentation:
I assume you can only access the parameters of the node in which the VEX snippet lives? On the right, i tried changing the 'size' of the box, but it doesn't work. Of course it needs a path.
And i assume you can't change/write the parameters that are above the current Wrangle node with something like ch(), right?
5c794fcf34828_Screenshot2019-03-01at16_19_37.thumb.png.9e29bd9cdf1f1636106523b965d8f3a1.png
Thanks.
Edited by DévinOdforce
first of all you can't change parameter values with VEX at all
to access them you need to use ch(), chi(), chf(), ... this way you can access any parameter from the scene, however I'd advise only accessing parameters directly on the Wrangle and channel reference others in them if you need to to properly track the dependencies
that part is super specific to VEXpressions, it's just because many of the parameters on such nodes (mostly POP DOPs) are actually referenced in the VOPnet and passed through snippet as arguments of the same names, therefore it seems that you can access those parameters and alter them, while in reality you are modifying a variable passed to the snippet and initialized wit the parameter value, then the result of the snippet is used
dive into any of those nodes to observe how it's all connected
  • Thanks 1
