herr.ja Posted March 7, 2019 Share Posted March 7, 2019 Hello Houdini people! May I have a simple question on U? Im trying to make a render of extreme difficult scene, with a lot of lights and textures with redshift. But unfortunately I can let rendering my computer only durring the night (because durring day I need it for my work ). The render which Im trying to make usually takes almost 20 hours, but as I wrote when I need the computer I have to stop it and then start again, because the render is unfinished (in corners because the buckes didnt finish it there) and also its unusable. What I need is lets say select some part of camera view and render it (RENDER TO DISK !!), basically I will divide whole frame on small parts (each part per night lets say) and then I will put them together in photoshop. So my question is: Is possible to select region in camera view (for example like in Blender/Cycles: its Shift+b+LMB) and then render this selected region to disk (I do not want render in scene view)? Thanks a lot for any advices!! Bye! Quote Link to comment Share on other sites More sharing options...
bonsak Posted March 7, 2019 Share Posted March 7, 2019 If you select the camera you can drag the red handles in the viewport to set up a crop on the camera for the rendered image. Then you just render to disk: 2 Quote Link to comment Share on other sites More sharing options...
herr.ja Posted March 7, 2019 Author Share Posted March 7, 2019 Oh! thank You so much! So easy, I didnt know that! Quote Link to comment Share on other sites More sharing options...
