Questions on Parameter Interface
Hey magicians,
I'm creating a setup to make vehicles, where you have different options for each part:
- For example to create the main base body, you can 1) use noise / 2) use a spline / 3) use a box
So far I have been using switch and sliders, but is getting more complex and I would like to do it the proper way, so anytime I pick a mode on dropdown (instead of slider), then the correct submenu appears.
Made an image to explain:
And here's a quick gif with the options:
Any tutorial suggestions for this, or tips on better organization, will be super useful.
Thanks in advance
Cheers!
  On 3/7/2019 at 10:21 PM, caskal said:
I have a switch from Normal geo to VDB.  I want to use a toggle to switch this both methods, so when is ON is VDB, when is OFF is normal geo.
Any thoughts?
Expand
reference the toggle in the switch sop input parameter, like ch("../mytoggle")
  • Thanks 1
