Fluorescent Effect
Do you guys have any idea how can I obtain simple fluorescent effect, or how can I make an object to emit light?
thanks
28321[/snapback]
Serwus Kuba,
If you mean a simple GI emitter, for a quick example apply a vex constant shader with high color values (like 10), create a light with gi shader and you are done.
If you don't want to use GI you can try instantiating lights on your object.
Serwus Kuba,
28344[/snapback]
You can also set your Light Object to be an Area light and set the shape to be a Line. To get reasonably accurate shadows you have to use raytraced shadows and so it can get expensive, so be a little careful.
