konstantin magnus Posted March 9, 2019 Share Posted March 9, 2019 (edited) Hi, I was shaping a hex nut with VEX when two geometry questions arose: How can I mathematically define the offset from a circle to an n-gon? Currently I am multiplying by a magic number: sin(u_mod) * 0.12. How can I multiply vectors so they end up on an infinite plane defined by a position and a normal? Kind of what planepointdistance() does, but rather intersecting the plane with the points vector than just returning the closest position on the plane. Also I would not want to shoot rays around but rather set this mathematically. Here is how I deform the tubes outer points at the moment: float u = atan(v@P.z, v@P.x); float u_mod = abs(sin(u * 3)); float u_fit = fit01(u_mod, 0.75, 1.0); vector nml_flat = normalize(v@N * {1, 0, 1}); v@P -= nml_flat * sin(u_mod) * 0.12; v@P.y *= u_fit; Thank you! hex_nut.hiplc Edited March 9, 2019 by konstantin magnus Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 9, 2019 Author Share Posted March 9, 2019 I exposed some parameters, in case someone is looking for a screw nut / cog wheel generator ; ) hex_nut.hiplc 4 Quote Link to comment Share on other sites More sharing options...
symek Posted March 9, 2019 Share Posted March 9, 2019 4 hours ago, konstantin magnus said: How can I multiply vectors so they end up on an infinite plane defined by a position and a normal? By "multiplying" you mean projecting them onto a plane? If so, cross() seems to be enough: // P is a vector in world space and POS, NORM are point // and (unit) normal vector defining infinite plane vector p0 = P - POS; vector projected = cross(p0, NORM); projected = cross(NORM, projected) + POS; 1 Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 9, 2019 Author Share Posted March 9, 2019 2 hours ago, symek said: By "multiplying" you mean projecting them onto a plane Thank you! And yes, by 'multiplying vectors' I was thinking of extending or shortening them, not thinking of using cross products here. So this is a visual summary in 5 steps: When we want to project the grey points from the inner circle on the plane of the outer points and their normals (turqoise), we aim in the opposite direction facing away from the plane points by subtracting circle point positions from the plane positions (yellow), create rectangular vectors to the plane normals by calculating a cross product of the aim direction and the plane points normals (red), and build the cross product of the planes normals and the rectangular directions while adding the planes position (green). When applying this result to the circle points positions, all points are projected on their targeted planes. int pt_plane = nearpoint(1, v@P); vector pos_plane = point(1, 'P', pt_plane); vector nml_plane = point(1, 'N', pt_plane); v@dir = v@P - pos_plane; // yellow v@rect = cross(v@dir, nml_plane); // red v@proj = cross(nml_plane, v@rect) + pos_plane; // green v@P = v@proj; project_on_plane.hiplc 1 Quote Link to comment Share on other sites More sharing options...
symek Posted March 9, 2019 Share Posted March 9, 2019 (edited) Oh man! You did art with those vectors. I'm jealous! Edited March 9, 2019 by symek visual proof added! 1 Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 9, 2019 Author Share Posted March 9, 2019 Well, there wouldnt been a single line without your brain ; ) Quote Link to comment Share on other sites More sharing options...
symek Posted March 9, 2019 Share Posted March 9, 2019 My brain is pleased Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted March 9, 2019 Share Posted March 9, 2019 Hi, nice tool! I've modified your example a bit avoiding using sinus but projecting the vectors onto planes instead. hex_nutX.hipnc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 10, 2019 Author Share Posted March 10, 2019 One question remains: How would one scale radial vectors so a circle turns into an n-gon? Quote Link to comment Share on other sites More sharing options...
acey195 Posted March 10, 2019 Share Posted March 10, 2019 I'm quite fond of this function: http://www.sidefx.com/docs/houdini/vex/functions/planepointdistance.html pretty sure you would be able to use it in your case (not completely sure how it will operate at the corners, but on the straight bits I imagine it should work pretty well) Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted March 10, 2019 Share Posted March 10, 2019 Here is a quick and dirty approach...Circle_To_NGon.hipnc Quote Link to comment Share on other sites More sharing options...
symek Posted March 11, 2019 Share Posted March 11, 2019 On 3/10/2019 at 2:55 PM, konstantin magnus said: One question remains: How would one scale radial vectors so a circle turns into an n-gon? int num_faces = chi("num_faces"); int nface = floor((float)@ptnum * num_faces / @numpt); float alpha = M_PI * (1+2*nface) / num_faces; int pin = nface * @numpt / num_faces; vector nml = set(cos(alpha), 0, -sin(alpha)); vector pos = point(0, "P", pin); @P = @P - pos; @P = cross(@P, nml); @P = cross(nml, @P) + pos; Those divisions by num_faces distract me, but I can't do better Quote Link to comment Share on other sites More sharing options...
