Iterate over an attribute
Is there a way to iterate over an attribute and copy specific geometry per matching value?
Currently I'm isolating the points with the same value and the meshes with the same value, then copying to points. I want to automate that part.
Say I'm copying over points and each point has 1 value per MaxHandle out of 6 possible. Then I have 6 meshes with said MaxHandle values in another node. I want to copy the meshes with the same MaxHandle to the point with the same value.
  • 4 weeks later...
Did this setup and forgot to post it! If anyone finds it helpful, here it is:
Where "MaxHandle" is the attribute you want to match.
It'll copy the matching meshes to points, based on the same attribute.
